Solved X axis code
Results 1 to 3 of 3
Thread: X axis code
    Default X axis code
    Hi I have a Syntec controller and I am getting a error on the x axis 21.1
    But the x axis is not moving it is moving in Y so I think there is a connection issue?
    Aug 2017
    China
    Default Re: X axis code
    when you press Y axis key ,check if X axis moving . if press Y ,X axis moving ,check the single cable connection etc .
    we found a bare wire grounding out sorry I dont get on here to much to update
X axis code
X axis code
