- Problem- Anilam SA Series Inverter Spindle Enable (HS2)
I have an Acer 2240A with Anilam SA 301A Inverter. Can not clear Spindle System Halt (HS2) on X71 Connector Pin1 and Pin 3.
The Enable +24VDC is present at pin 1 and pin 3. A jumper across these pins does not Enable the spindle drive. Any ideas how to repair this enable input on X71, pin 3?
- You may not post replies
- You may not edit your posts
Forum Rules
