Good cnc lathe controller
Results 1 to 4 of 4
Thread: Good cnc lathe controller
    Dec 2011
    Usa
    Default Good cnc lathe controller
    I might be looking at putting a new control system on a lathe I have.
    Any one have any suggestions on a good control?
    I have several centroids. Good control, lacking on conversational programming and speed.
    I know the Mach 3,4 stuff is junk. I need a pro level system.
    Fanuc & Siemens are pricey and have zero support.
    Dec 2013
    Default Re: Good cnc lathe controller
    I sent you a PM.
    Jim Dawson
    Sandy, Oregon, USA
    Member Algirdas's Avatar
    Mar 2009
    United Arab Emirates
    Depends on what exactly you need to control. What safety system you want to implement? What are drives: spindle; X axis, Z axis. Is there any gearbox? What is hydraulic system? Parts catcher, bar pusher? What is turret drive and many other factors. I would start to see the encoders first and desice if I leave them as is or I will upgrade. Motor drives - the same story. Is it better to install new ones or leave present.
    Evaluate availability of new hardware components. Then you can figure out what the control specification will be - how many analog signals, what buses, how many digital inputs / outputs.
    I would say the Linuc CNC is quite flexible if you are not afraid to dig deep into operating system.
    Sep 2011
    australia
    Do any retrofits have good conversational programming?
