- Problem- Esa Tria 7500 PLC.
Esa Tria 7500 PLC.
Morbidelli Author 504 ( 1997 3-ax + vector ax )
I have got out off the blue the next error in red capitals: 0000 PLC BLOCK.
I contacted SCM in the netherlands They said that it was a problem with the backup .( New back-up battery for less than a year ?)
New battery, program and parameters loaded.
After switching on the machine the x-ax started uncontrolled moving without touching the calibration button.
Has anyone a suggesting what this could be, ore what to do?
( an other Esa Tria 7500PLC is welcome)
Re: Esa Tria 7500 PLC.
Hi there,
I know I'm a little late but have you looked at the X axis drive?. When the machine is in Estop, and you push the x axis by hand, does the position count correctly on the screen? Have you checked the cables to the x-axis. They pass through the drag chain and could be damaged
Let me know how you get on
Louis
Did you get it working with the x-axis?
I have a Author 504 with 3-axis + vector. My machine started to "jump" uncontrollable on the x-axis. The serviceman managed to locate the problem to the analog controlcard. The voltage was way high on the output pins. After a switch to a new one it's working like a charm!
Regards
KJ
- You may not post replies
- You may not edit your posts
Forum Rules
