smc5-5-n backlash control
Results 1 to 3 of 3
Thread: smc5-5-n backlash control
    May 2013
    Gilligans Island
    Default smc5-5-n backlash control
    Hello, i have a similar issue to some 3d printers, no backlash control.
    Some 3d printers have an M99 code, one sets the backlash at the head of the program.
    Could this function be copied and pasted into smc5-5-n firmware?
    Attached Thumbnails Attached Thumbnails smc5-5-n backlash control-20201121_084708-jpg   smc5-5-n backlash control-20201121_084759-jpg
    Jun 2009
    Finland
    Default Re: smc5-5-n backlash control
    The firmware version 2020-09-16 already has backlash control, separate for each axis. You can get the latest firmware from Lollette support if you send them the serial number of your SMC5-5-N-N controller. Hopefully they'll add other useful functions as well for future firmware versions, as the controller functionality is still quite limited with several not-yet-in-use front panel buttons, for example.
    May 2013
    Gilligans Island
    Good to hear, i only bought smc5 because ddcsv cannot be upgraded to 5 axis, it has to be built in from the get go.
    Wisdom results from foolishness!
