Either one of those adapters should work.. That old PC would probably work too; you don't need to use it for anything else but running the router, so you don't need to deal with Windows updates (turn off the automatic update function entirely, since it just interrupts cutting). You don't need to install drivers either, unless you're using it for other things, which isn't recommended. But you'll get better throughput by using a newer computer and an adapter.
