- Morbidelli A504 Rapid wrong toolnumber
Hello,
I have a Morbidelli A504 rapid with a disc toolchanger.
I restarted my machine after a lightningstrike and got everything back.
The problem now is that it thinks a tool from position 55 is in the spindle but I only have 6 positions. When the machine itself tries to remove the tool, the disch spins and stops in between the holders, which means it cannot get a hold of the tool causing a 690 error magazine in/out.
I can do the toolchange by manually moving the magazine in the tria menu. But when I'm done it still says tool from position 55 is in the spindle. The machine itself is running so it's just the little detail in changing tools automatically that is the problem.
Any idea in fixing it?
Thanks in advance!
K-J
Re: Morbidelli A504 Rapid wrong toolnumber
Hi KJ
Did you get this problem solved?
Louis
- You may not post replies
- You may not edit your posts
Forum Rules
