RZNC 501 controller issues
Results 1 to 2 of 2
Thread: RZNC 501 controller issues
    Dec 2006
    Singapore
    Default RZNC 501 controller issues
    Hi all,
    been using the RZNC 501 controllers for 3 -4 years.
    Every time i start the new cutting process, the system will automatically goes to SPD GRAD 7, even though during the processing menu, I set it to SPD GRAD 1, it will still runs at SPD GRAD 7 during the cutting process.
    Another question i have: I am using ArtCam. But i cannot seems to set the speed of the milling process using the RZNC controller.
    Example i set 5000rpm on my ARTCAM, but my RZNC 501 controller only seems to runs at the speed set on the RZNC controller. I can only manually set the speed using the RZNC controller during the milling process.
    Thanks, hope you guys can help me in these issues.
    Ivan
    Member ZASto's Avatar
    Apr 2005
    Vanuatu
    Default Re: RZNC 501 controller issues
    RZNC does not "understand" S parameter in G-Code, it ignores it.
    SPD GradeX is an combination of output levels on 2 pins that are connected to your VFD inputs, and speeds are programmed in VFD.
    So, there is no way to control speed via G-Code, unfortunately.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
