Hi
I had some problems to get the UC400ETH to connect in mach3, (displaying blue light on the unit).
A lot of google time did not help me, but the solution was actually hinting me. Mach3 is giving information about firmware update, but I was receiving error when I tried to update.
The solution is to make sure that you select all UC400ETH plugins in Mach3 plugin configuration.
You should have only one UC400ETH plugin in the Mach3 folder. If you have more than one that is a problem.Hi
