Controller board to cut Bezier curves?!?? - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: Controller board to cut Bezier curves?!??
  1. #13
    Jul 2017
    Italy
    Default Re: Controller board to cut Bezier curves?!??
    Follow a sample code to get a 2 dimension bezier (XY) of 3 degree using RosettaCNC macro language (compliant with Fanuc-B macro language).
    Controller board to cut Bezier curves?!??-400px-bezier_curve-svg-png
    Code:
    G17 G21 G40 G49 G80 G90
    G54
    G52 X200 Y200
    G0 X0 Y0
    F1000
    ; Sample of path with 3 bezier curve (3 degree)
    G65 P1000 T0.01 A0 B0 C0 D50 E100 F50 I100 J0
    G65 P1000 T0.01 A100 B0 C150 D-25 E220 F-10 I180 J0
    G65 P1000 T0.01 A180 B0 C180 D75 E120 F200 I0 J50
    M2
    ; create a degree 3 Bezier curve
    ;   dt      T   #20
    ;   p0.x    A   #1
    ;   p0.y    B   #2
    ;   p1.x    C   #3
    ;   p1.y    D   #7
    ;   p2.x    E   #8
    ;   p2.y    F   #9
    ;   p3.x    I   #4
    ;   p3.y    J   #5
    O1000
    ;   local variables
    ;   #1000 = t
    ;   #1001 = x0
    ;   #1002 = y0
    ;   #1003 = x1
    ;   #1004 = y1
        #1000 = 0.0
        ; calc x1 & y1
        G65 P1001 T#1000 A#1 B#3 C#8 D#4
        #1003 = #100
        G65 P1002 T#1000 A#2 B#7 C#9 D#5
        #1004 = #100
        ; t = t + dt
        #1000 = [#1000 + #20]
        WHILE [#1000 LT 1] DO01
            ; x0 = x1
            #1001 = #1003
            ; y0 = y1
            #1002 = #1004
            ; calc x1 & y1
            #1003 = #100
            #1004 = #100
            G1 X#1001 Y#1002
            X#1003 Y#1004
            ; t = t + dt
        END01
    M99
    ; X function for a degree 3 Bezier curve
    ;   t       T   #20
    ;   x0      A   #1
    ;   x1      B   #2
    ;   x2      C   #3
    ;   x3      D   #7
    ;   #100 =  x0 * (1 - t) ^ 3 +
    ;           x1 * 3 * t * (1 - t) ^ 2 +
    ;           x2 * 3 * t ^ 2 * (1 - t) +
    ;           x3 * t ^ 3
    O1001
        #100 = [ 0    + [#1 * [[1 - #20] ** 3]] ]
        #100 = [ #100 + [#2 * 3 * #20 * [[1 - #20] ** 2]] ]
        #100 = [ #100 + [#3 * 3 * [#20 ** 2] * [1 - #20]] ]
        #100 = [ #100 + [#7 * [#20 ** 3]] ]
    M99
    ; Y function for a degree 3 Bezier curve
    ;   t       T   #20
    ;   y0      A   #1
    ;   y1      B   #2
    ;   y2      C   #3
    ;   y3      D   #7
    ;   #100 =  y0 * (1 - t) ^ 3 +
    ;           y1 * 3 * t * (1 - t) ^ 2 +
    ;           y2 * 3 * t ^ 2 * (1 - t) +
    ;           y3 * t ^ 3
    O1002
    M99
    You get this:
    Controller board to cut Bezier curves?!??-bezier-jpg
    The inner macro can be used to creare a new user-defined G code (Eg: G300):
    Code:
    G54
    G52 X200 Y200
    G0 X0 Y0
    F1000
    G300 T0.01 A0 B0 C0 D50 E100 F50 I100 J0
    G300 T0.01 A100 B0 C150 D-25 E220 F120 I180 J0
    G300 T0.01 A180 B0 C180 D75 E120 F200 I0 J50
    G300 T0.01 A0 B50 C73 D80 E20 F100 I210 J50
    M2
    And obtain:
    Controller board to cut Bezier curves?!??-bezier2-jpg
    A video of toolpath executed in CNC:
    Attached Thumbnails Attached Thumbnails Controller board to cut Bezier curves?!??-bezier-jpg   Controller board to cut Bezier curves?!??-bezier2-jpg   Controller board to cut Bezier curves?!??-400px-bezier_curve-svg-png
  2. #14
    Jul 2017
    Italy
    In this last example I've matched a circle made with bezier with a native circle made with arcs.
    The G300 macro is changed to use K instead of F and missing last segment added.
    G300 Macro code:
    Code:
    ;   dt      T   #20
    ;   p0.x    A   #1
    ;   p0.y    B   #2
    ;   p1.x    C   #3
    ;   p1.y    D   #7
    ;   p2.x    E   #8
    ;   p2.y    K   #6
    ;   p3.x    I   #4
    ;   p3.y    J   #5
    O1000
    ;   local variables
    ;   #1000 = t
    ;   #1001 = x0
    ;   #1002 = y0
    ;   #1003 = x1
    ;   #1004 = y1
        #1000 = 0.0
        ; calc x1 & y1
        #1003 = #100
        G65 P1002 T#1000 A#2 B#7 C#6 D#5
        #1004 = #100
        ; t = t + dt
            ; x0 = x1
            #1001 = #1003
            ; y0 = y1
            #1002 = #1004
            ; calc x1 & y1
            #1003 = #100
            #1004 = #100
            G1 X#1001 Y#1002
            X#1003 Y#1004
            ; t = t + dt
        END01
        ; connect final point
        #1000 = 1
        ; x0 = x1
        #1001 = #1003
        ; y0 = y1
        #1002 = #1004
        ; calc x1 & y1
        #1003 = #100
        #1004 = #100
        G1 X#1001 Y#1002
        X#1003 Y#1004
    M99
    ; X function for a degree 3 Bezier curver
    ;   t       T   #20
    ;   x0      A   #1
    ;   x1      B   #2
    ;   x2      C   #3
    ;   x3      D   #7
    ;           x3 * t ^ 3
    O1001
    M99
    ; Y function for a degree 3 Bezier curver
    ;   t       T   #20
    ;   y0      A   #1
    ;   y1      B   #2
    ;   y2      C   #3
    ;   y3      D   #7
    ;           y3 * t ^ 3
    O1002
    M99
    Sample code:
    Code:
    G17 G20 G40 G49 G80 G90
    G54 F100
    G52 X2 Y2
    G0 X0 Y1
    G64 Q.01 P.01
    ; select T1 color
    M61 Q1
    ; control point for 1 inch radius
    #1=0.55191502449
    ; circle of 1 inch with bezier curve
    ;     dt    p1.X  p1.Y  p2.X  p2.Y  p3.X  p3.Y  p4.X  p4.Y
    G300 T0.01  A0    B1    C#1   D1    E1    K#1   I1    J0
    G300 T0.01  A1    B0    C1    D-#1  E#1   K-1   I0    J-1
    G300 T0.01  A0    B-1   C-#1  D-1   E-1   K-#1  I-1   J0
    G300 T0.01  A-1   B0    C-1   D#1   E-#1  K1    I0    J1
    ; select T2 color
    M61 Q2
    ; circle of 1 inch with g2
    G0 X0 Y1
    G2 X0 Y1 I0 J-1
    M2
    Result:
    Controller board to cut Bezier curves?!??-bezier-circle-jpg
    Video:
    In next days I will try to create a macro to manage cycles with NURBS control points eg:
    Code:
    G66 p"nurbs" Q1 L3
         X0 Y1 Q1
         X2 Y2 Q1
         X2 Y0 Q1
         X0 Y0 Q2
    G67
    Attached Thumbnails Attached Thumbnails Controller board to cut Bezier curves?!??-bezier-circle-jpg
