Galil Motion Control products do that. And if the plugin is working should be compatible with Mach4. Not sure if Mach4 supports dual loop setups.
I am currently running Mach 4 with Allen Bradley Ultra 3000 AC servo drives. This is open loop from the perspective of the control, but closed loop at the motor. I am curious (educational use only) if there are any control setups that would allow a second position loop to be closed at the control using glass scales mounted on the machine. I could setup the servos as velocity loop only and use a control like CSLabs CSMIO to close the position loop, but I have never seen a Step/Dir controller which allowed you to close the loop.
- Motion Control Board Selection, any USA made boards with support?
- Need Help!- Closing the loop with Path Pilot. Possibly dual (global) closed loop?
- Need expert opinions, closed-loop, configurable, SPI compatible motion-controllers?
- Just IN- Techsoft Motion Control,Low cost,Brush/Brushless Servo Motors,drives/controllers
- Anyone familiar with "Motion Control Products" company?
Jim Dawson
Sandy, Oregon, USA
I don't know if I am reading this correct but I am using Yaskawa AC servos these can be configured to out put a error if it they do not arrive at the requested position I use this error in Mach3 to shut down the system.
LinuxCNC can do this for you.
Inner Vision Development Corp. - http://www.ivdc.com
Website Design & Development. Shopping Carts, SEO and more!
Option 1: Delta AC servo controllers have both motor encoder input and table linear encoder input. They have encoder output signal + position error alarm signal. Dual loop can be closed at the servo controller.
Option 2: SZGH Auto CNC controllers (china) have encoder inputs for each axis. Dual loop can be closed at the controller.
Option 3: combination of the 2 above
I started to cnc my mill using option 2. I do not know at the moment how it will work
Sent from my SM-A520F using Tapatalk
