Need Help! How to use Richauto A11 to control external equipments.
Results 1 to 3 of 3
Thread: How to use Richauto A11 to control external equipments.
    *Registered User* dungvv's Avatar
    Jan 2019
    Default How to use Richauto A11 to control external equipments.
    I'm using a wood lathe machine with 3 axis.
    My controller is RichAuto A11.
    I want to turn on and turn off a fan by G-Code.
    Can you help me?
    How to do it?
    Many thanks.
    Alex
    Member he1957's Avatar
    Jun 2018
    Tasmania
    Default Re: How to use Richauto A11 to control external equipments.
    Have not tried this and the manual does not specifically state but the following M codes with Output Y8 _might_ work:
    M350 Output Logic Zero
    M351 Output Logic One
    These are claimed to be the "extension output" but they do not state it is Y8 however, this is the only output not flagged for use by anything else in their manual.
    Under the cover there are some LED's to indicate the state of the outputs so it should be easy to check.
    The A11 and its motion card are minimal and do not have a lot of flexibility/expandability.
    Let us know if this works or not. If it works, this output could be connected to a SSR to control some external device.
    Jan 2019
    Quote Originally Posted by he1957 View Post
    Thank you very much. I will try it.
