- Anilam 3200MK software Maybe?
Hi, everyone.
The hard drive died on my 2 axis mill with a 3200MK control. The original software version 3.12A is not recoverable.
I installed another HDD, with software ver.3.62 from a 3300 control.I set the configuration for 2 cnc axis and the z as DRO.
Everything works but the axis are unstable / jerking. The servos, motors and filter parameters ar all correct. The DAC signal voltage from the DSP is pulsing up or down randomly.
I think the software is the problem, not compatible with DSP.
QUESTION... Can anyone please help with a copy of software for a 3200 control or offer any advice?
Thanks in advance
Re: Anilam 3200MK software Maybe?
You may just have to tune the servos, the manuals are available online and have a section on tuning
Sent from my iPhone using Tapatalk Pro
Thanks for the input.
In case anyone is interested the problem was the digital to analog chip on the DSP board.
- You may not post replies
- You may not edit your posts
Forum Rules
