- Fanuc controller can access the files in FTP server but gives file size error
*Registered User*
Hi all,
I've configured Fanuc 16i controller and my PC. I can reach all files on my PC from Fanuc via FTP . But when I try to read and run these pogram files I can't. It gives something like size error. As I guess, 16i has 512 KB memory, but the files are bigger than 512 KB. So it doesn't run the files.
But, when I put the same files on memory card, it works. It means, Fanuc reads files on memory card block by block or line by line, but it doesn't do the same thing for files on FTP server.
Is there a parameter for this to fix? Can you help?
Thanks,
Semih.
- You may not post replies
- You may not edit your posts
Forum Rules
