Amada Promecam APX100 getting into BIOS settings
Results 1 to 8 of 8
Thread: Amada Promecam APX100 getting into BIOS settings
    May 2010
    uk
    Default Amada Promecam APX100 getting into BIOS settings
    Hello, machine's an Amada Promecam Press Brake APX100 with OPE-2 'operateur' cnc based on an SBC board.
    The BIOS battery died at the weekend and has reset the clock to 1/1/1980.
    When booting up, the POST screen says the CMOS battery is faulty, and to press ESC to continue or CTRL-ALT-DEL to enter settings.
    The problem is that we dont have either an ESC, CTRL, or ALT on the 'operateur' keyboard.
    Does anyone know how to get into the BIOS setup, please?
    It's too old for Amada to know, their engineer told us to write- off the machine.
    I would try to plug a standard PC keyboard in but the motherboard only has pin headers for everything.
    Best regards
    kevin
    Amada Promecam APX100 getting into BIOS settings-amada-jpg
    Oct 2008
    Default Re: Amada Promecam APX100 getting into BIOS settings
    Your best bet is probably to send a PM to "AmadaJoe" here on CNC Zone. He's an ex-Amada tech and operates Alternative Parts Inc in the USA. Extremely knowledgeable guy.
    https://www.cnczone.com/forums/members/amadajoe.html
    Mar 2009
    "It's too old for Amada to know, their engineer told us to write- off the machine." LOL..That is funny. You need a special cable to hook up standard PC keyboard. Email me pictures of your CPU. Amada uses several CPU's. I will send you pin configuration and location. Side note I am parting out 2 of these machines if you need anything else. 2204
    Best regards,
    JOE@ALTPARTS.COM
    Mar 2009
    Quote Originally Posted by Hemikiller View Post
    Hemikiller, Thanks for the kind words.
    Cheers
    Oct 2008
    Quote Originally Posted by AMADAJOE View Post
    Cheers
    Bought parts from you guys in the past, always spot on.
    Member schwemmi9999's Avatar
    Mar 2019
    Hi, I have the same problem. Have you a pinout for assembling a keyboard?
    best regards Peter
  7. #7
    May 2010
    uk
    Amada Promecam APX100 getting into BIOS settings-adapter-jpg
  8. #8
    Member dule's Avatar
    Oct 2019
    Hi guys i have a problem witha AMADA PRESS BRAKE HFB 1254 we had to replace original mother board the cpu didnt worked good. We had replaced that with vdx -6324rd and now we cant boot system again does anybody knows how to fix that
