- Need Help!- CNC Control for Turntable
25" turntable equipped with a 1hp 90vdc brushed motor controlled by a manually operated forward/reverse, variable speed control. The unit also has an encoder attached to drive shaft that provides input to a digital read out. Would like to add cnc control to the unit that would allow the operator to enter a number of angular positions required for the job and then sequentially turn to the positions upon operator input. Table rotates through the positions multiple times during the job. Looking for recommendations on how to do this in a cost effective manner with small control package size, and weight, that could be mounted on an existing movable operator console. Alternatively the operator console could have a pushbutton and dro with the remainder of the control hardware mounted near the turntable. Any recommendations would be appreciated.
- You may not post replies
- You may not edit your posts
Forum Rules
