Good afternoon:
I have a Herluce EP4030 model year 2000 milling machine,
it is the same as the Isel ICV 4030.
It uses the nascad 2000 software.
Would it be possible to use other software such as mach3 or similar?
The problem is that it is executed by msdos in a windows 98 and I would like to put it in a more modern computer.
Attached screenshots of the program
this is the home screen
here you have to choose ISEL-EP.EXE
This screen is for moving Y X and Z axes
And this is the program files.
The executable is NC.com
The license is in a parallel port, and the machine is connected to the PC through a serial port cable.
Could you use another program easier and in a more modern computer?
Regards
