Need Help! RICHAUTO A11E - No USB?
Results 1 to 5 of 5
Thread: RICHAUTO A11E - No USB?
    Dec 2016
    Default RICHAUTO A11E - No USB?
    Hi Everyone
    I recently purchased an cnc router that is controlled by a RICHAUTO-AUTONOW-A11E controller.
    The problem i have is that it will not recognise and usb sticks or the computer. When i try to read the USB stick is just states "There is no item in this directory." I also can't work out how to get the controller to plug & play to the computer.
    I have tried
    15+ USB sticks
    safe removing usb sticks
    Several different .tap & .nc file formats.
    3 different usb leads to the computer.
    clearing currently saved files.
    powering up the unit with usb in already
    powering up and then plugging in the usb
    reading the 60 page chinglish manual over & over thinking i missed something.
    different usb ports
    different computer
    I am not getting and lights on the USB stick so i am not sure if the controller is faulty or whats going on.
    I'm also not sure if i am even trying to access the files correctly as the manual is so bad.
    Can anyone with experience with this controller please give me some guidance.
    After sales service is no good due to Christmas / New Year holidays
    Ben
    Dec 2016
    Default Re: RICHAUTO A11E - No USB?
    Anyone got and advice. More info needed?
    Dec 2013
    I got the same model and same problem
    did you find a solution?
    Member he1957's Avatar
    Jun 2018
    Tasmania
    To see the handle via USB to PC:
    1. power it up while holding the OK and CANCEL buttons.
    2. Leave the CNC machine OFF, use item 1 and connect USB cable to handle
    If you do the above, the handle needs to be power cycled to then control the machine.
    Filenames on a USB stick work with *.NC extension. Try using the RUN/PAUSE button to access the UDISK (external USB).
    Also, go through the SETUP screens to ensure all is enabled for what you want. Note that the A11 propable needs to be to to honour G and M codes from programs otherwise it might ignore settings like "F" for speeds.
    Member ahmad00syr's Avatar
    Apr 2020
    I have this problem and it is solved by formatting the USB stick to FAT32.
