I have the steps and the disk.. of the Tria-7500
but my Machine it's an Author 504K
And I don't know... if they are compatible......
Need urgent help for a Tria 7500 controller. Back-up batteri is gone dead, so the controller lost all data. Need help for the procedure to reinstall data. Got disk whith all data on (original) but need help step for step.
- Need Help!- morbidelli 504 tria 7500
- Tria 7500
- Need Help!- Morbidelli Author 503 (1995) Tria 7500
- TRIA 7500 software missing
- Need Help!- 'Errore Generico' Morbidelli tria 7500
Thank`s for the reaktion. It is working on a 503 STC, and we are now running again. The codes to be set is diffrent on the 2 maschines. For a Author 503 STC is it 1194121 space 1195457. I hope it can be usefull for others.
Stoned.
I have a morbidelli 504k and I need PLC and wakeup code . Thanks
Hey Ronnieworks.
I have got both code and procedure to load plc files agin. If i get your mail address i will send it to you as attached word file. You probartly forgooten to renew the back up battery, i tried it myself.
Best regards: Stoned
ronnie_52132@yahoo.com Thanks
Is your 504k with a twin pack and tool drawer if so could I get the plc and parametors and wake up code.
Have codes and reload procedure for Author 504 and Author 503. email me at jgriminger@wallsforms.com
NEED HELP with sizing on Morbidelli Author 503. Keep getting error 547 (Magazine Draw Back) when the machine DOES NOT have a tool magazine. jgriminger@wallsforms.com
bonjour
j'ai ma disquette parametre "HS" et doit les recharger sur la machine
est ce que quelqu'un a ces parametres.
merci
Need Help! Tria 7500 Author 503 morbedelli with automatic tool exchange:Can not find the proper start up discs ours seem to not be working ... contacted scm in the states with no luck tried calling UK with no reply yet. Can anyone help ? Thank you !!
Hi all.
Is there anyone who can tell me if you can use G code X Y Z generatet from PC then transfered to the CNC by floppy disk?
example would be nice
I ask because right now we program directly on the CNC point to point and we use autocad to get the point to points and then punch them in manualy and some of the programs are very very long so it would be good to have a program where you can import the autocad drawing and generate the X Y Z and just copy it to a floppy disk and load it as a SUB program.
Any ideas is helpful guys.
Best regards
Flemming
I do not understand your question, you mean to create a file and then copy it to CNC?
Usually uses CAD/CAM Sofware.
but for TRIA controls, you need a system that converts
ASCII to PGM
Some CAD/CAM Software to Programing TRIA 7xxx Controls are:
ASPAN
XILOG PLUS
ALPHACAM
I hope this information is helpful...
Plz help me i have morbi 504 and i need help for load plc ste by step email redline5@rambler.ru
I sent to you the Steps to load PLC data in AUTHO504
By Email..
Hola Baldo.
Soy de Madrid (España), ¿Me podrías enviar por E-mail los pasos para cargar el programa de PLC en
el AUTHOR 504. Muchas gracias. jesus@hebersl.com
Hi. Somebody have the user´s guide for program morbidelli 503, the list of g-codes available and I need access to the list of corrector x and y. thanks
Julio
XILOG PLUS software is special for TRIA controls
and has a programming guide, G00, G01, G02 etc.
I have a morbidelli author 504. Replaced the battery and could not get it started again. Keep getting message that the plc is blocked. Can someone please help me or post me some instructions on how to get it going again.
