Tria 7500 for Morbidelli Author 503 - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 76 of 76
Thread: Tria 7500 for Morbidelli Author 503
  1. #61
    Activation process Zeyadasd's Avatar
    Jun 2018
    Default Re: Tria 7500 for Morbidelli Author 503
    hi every on
    i need author 503 files to
    parameters , plc sequance and plc files too
    any help to get my machine work
    at Zeyadmamdouh27@gmail.com
  2. #62
    Jun 2018
    Quote Originally Posted by Apprenticejim View Post
    Hey guys, I am glad everybody's problems have been solved.
    Now it's my turn. Could someone please help me wake-up my 503 author?
    I need the plc and parameter files plus the instructions.
    Thanks in advance for the help, I appreciate it.I
    Apprenticejim@gmail.com
    dear friend do you have the files of author 503
    if you send them to me at : zeyadmamdouh27@gmail.com
    thanks in advance
  3. #63
    Also need a PLC and tool def files for author 510 any help would be awesome thank you so much..
    billh.psc@att.net
  4. #64
    Member Luisako's Avatar
    Feb 2021
    Dear friend do you have the files of author 503
    if you send them to me at : luisantonioperezcarrasco@gmail.com
    thanks in advance
    Espero me puedan ayudar, necesito los archivos y el método para revivir mi 503 que se quedó sin batería y uno de los discos no funciona. Si me pueden enviar los archivos les estaré eternamente agradecido.
    Gracias
  5. #65
    Feb 2021
    hi
    i need author 503 files parameters , plc sequance and plc files too any help to get my machine work
    at luisantonioperezcarrasco@gmail.com
  6. #66
    Feb 2021
    hi every on
  7. #67
    Member JackWood's Avatar
    Jan 2022
    Default Morbidelli Author 503
    Hello Everyone,
    Would you please send me steps on how to load PLC step by step? Including loading Tools and all the needed Data etc.
    The issue is that whenever I'm doing that from scratch all works except Tools box that does not slides out (it is OFF on display all the time and cannot enable it).
    The rest of functions works just fine.
    Email:jackwlczk@gmail.com
    Appreciate any help you may provide.
    Thanks,
    Jack
  8. #68
    Hello guys, i have prob with author 503. Batery was gone, so i need restore data which i have on some disc. But i need steeps and procedure how to done. I tried alone and plc mashine accepted but she trow out error for parameters.
  9. #69
    If some1 have PLC files for Author 504k i would be very happy if could sendt hem to b.bozym@home-concept.pl
  10. #70
    Member prtsard's Avatar
    Mar 2023
    Quote Originally Posted by stoned View Post
    Hey Ronnieworks.
    I have got both code and procedure to load plc files agin. If i get your mail address i will send it to you as attached word file. You probartly forgooten to renew the back up battery, i tried it myself.
    Best regards: Stoned
    Hello,
    I have an Author 503 and I need the PLC files and the steps to load them as my battery has gone dead.
    Please email them to me info@mobila-lemn.ro
    Thanks.
  11. #71
    Mar 2023
    Hello,
    I had a problem with an Author 503 STC, battery gone dead, and this is how I fixed:
    - First of all you need to have the two disk (files) with the PLC files and Parameters file regarding your machine. If you don't have them then you have to contact SCM, they had a data base with all the machines that were produced regarding this two sets of files.
    - Second, you need to format your RAMDISK, in order to clear everything there, then you have to enter the password to be able to load the proper files for TRIA. Next, you have to load from disk the PLC files, messages files and K constant files. After you can start the PLC from the RUN/STOP button.
    - Third, you need to load the parameters (from the disk).
    - Fourth, you have to start the PLC sequence. You go in the PLC Sequence menu, load it from the disk and compile it.
    - Fifth, you need to correct the parameters with the specific machine parameters(they should be provided with the machine and they have to be made by hand). Each machine has its own parameters who differ from the standard with couple of mm. Like this machine will know exactly every position of the heads, spindles, storage, table etc.
    - Sixth, you will have to load the tools programs, normally is defined "DEF"
    I know that is hard to put it back to the initial phase but I go through this and I will gladly help you if you need it.
    Just email me, info@mobila-lemn.ro
    Cheers,
    Radu
  12. #72
    Member squarewoodcraft1980's Avatar
    Jan 2022
    I have just gone through the dead battery restart as well if anyone needs a little assistance. On the flip side I am looking to get a post processor for this machine as well I heard that you can get programs to write pgm’s on remote computers and transfer to floppies. Does anyone know about this?
  13. #73
    Jinni's Avatar
    Jun 2023
    Default Re: Morbidelli A 503 STC
    Hi stoned . please can you send me the disk of Tria-7500 .I had them backuped ,and don't know the reason they are corrupted both Cannot find Triaset.Data. I hhave been running this Machine for about 10 years now ,but got a little bit sick and in the meanwhile the battery gone death .. Thank's in aadvance
  14. #74
    C3D's Avatar
    Jul 2023
    Quote Originally Posted by squarewoodcraft1980 View Post
    Puedo ayudarte con este tema. Tengo una Morbidelli U550. Todo el trabajo lo hago en un Pc donde se generan los archivos xxl para cada pieza del proyecto. Una utilidad los convierte en pgm. Los copio a una memoria USB. La maquina antes tenia disketes ahora tiene un lector USB.
    Mi correo es cuerpo3d@gmail.com.
    Por otra parte necesito ayuda de los pasos para volver a cargar los archivos de configuración, creo que los pasos son los mismos aunque la maquina no sea exactamente del mismo modelo. Tengo los archivos de configuración que en si dia copie de la misma maquina a una memoria USB.
    Gracias!
  15. #75
    C3D's Avatar
    Jul 2023
    Tengo un convertidor xxl pgm.
    Por otra parte necesito ayuda para volver a poner en funcionamiento mi maquina despues de agotarse la batería durante unas vacaciones. Al volver ya fue demasiado tarde reponer bateria nueva.
    Recomiendo cambiar de batería si vais a estar un tiempo con la maquina parada y la bateria tiene mas de dos años. Si yo lo hubiese echo ahora no tendría este problema
    Gracias!
  16. #76
    Member PRINTCITYMEDIA's Avatar
    Dec 2023
    Question Re: Tria 7500 for Morbidelli Author 503
    I could use a little help on this subject.... james@printcitymedia.ca
  17. #77
    Registered DonTL's Avatar
    Apr 2015
    toronto
    Hey Guys ..did you manage to get your machines up and running..I now have the same issue but I cant get the TRia to find the files from the disk..
  18. #78
    Apr 2015
    toronto
    Im having a similar issue..but I cant get my machine to read the floppy disks..I think its a password problem but Im not sure..could you let me know how you did it?
  19. #79
    Lolita80's Avatar
    Mar 2024
    Hello guys.
    I have a problem with a Cnc Morbidelli Author 503,
    The battery has gone and we lost the PLC configuration.
    If someone can help me with the parameters and procedure to upload again the plc I gonna appreciate it.
    Thank you.
    Lolita
    My email is roblesdolores03@gmail.com
