help configuration SCM RECORD 220 ROUTECH
Results 1 to 4 of 4
Thread: help configuration SCM RECORD 220 ROUTECH
    Apr 2014
    Default help configuration SCM RECORD 220 ROUTECH
    Hello. this is my first post, i hope someone can help me.
    i have this SCM RECORD 220 ROUTECH, we recently changed the CPU cause it was malfunctioning , some troubles with the HDD, we installed all the software on the new CPU no biggies, it connects and everything, problem here is that the SCM marks an error and blocks all the system, it says that the axys are not calibrated.
    i still have the backup from the previous HDD , it has all the files, i was wondering if there is a file that contains information i could use to recalibrate the SCM, or if somehow i can transfer the configuration from the NUM to the CPU .
    in the worst case it does not exists how can i recalibrate the axys so it can work again.
    thank you very much !
    *Registered User* MoHABT's Avatar
    Oct 2018
    Default Re: help configuration SCM RECORD 220 ROUTECH
    hi,
    I need a copy of a backup for SCM Record 220
    can you help me??
    Sep 2008
    MExico
    hi
    Can you share me the backup?
    Regards
    Member israosuna17's Avatar
    Mar 2020
    Hi sr
    Do you have the electrical diagrams and manuals
