Need Help! richauto A11 dsp control
Results 1 to 10 of 10
Thread: richauto A11 dsp control
    Jan 2016
    Default Re: richauto A11 dsp control
    Please, I have a problem with Richauto A11, I need PKG file for updating. Thank you,.
    Feb 2016
    Pakistan
    Quote Originally Posted by cyrilzde View Post
    Hi, Can anyone tell me that how can i connect Richauto A11 with my computer? All i got is .pkg file. How can i use this .pkg file
    Mar 2010
    Russia
    Quote Originally Posted by wajid View Post
    Obviosly you should connect it with both green and yellow buttons pressed, It turns internal memory to be connected to PC as USB card.
    New removable disk will open. Copy pkg file there, reboot unit and try flash it with internal upgrade procedure
    *Registered User* Mandegar's Avatar
    Aug 2018
    Hi
    do you have PKG file?
    I need
    THANKS
    *Registered User* kam50's Avatar
    Oct 2018
    I am also looking for the same
  7. #7
    Member he1957's Avatar
    Jun 2018
    Tasmania
    Seems their website is unavailable.
    Try contacting them via their Facebook page at: https://www.facebook.com/search/top/...6t%20co.%20ltd
    Comments:
    1. Save a copy of the current handle configuration before you do anything
    2. See their Facebook page to see how to set it from Chinese back to English after an upgrade (if this happens to you too :-))
    Cheers,
  8. #8
    Mar 2010
    Russia
    It's should be Jery Jiang, relation and support responsible person. He don't like to give support to any end customer.
    Obviously he'll tell you it's your problem, because you not buy DSP directly from Ritzahong.
    Here is what i have:
    But keep in mind, unit don't allow you load older FW. This one is q13-1292
  9. #9
    Jun 2018
    Tasmania
    The RichAuto website/download page is available again:
    Upgrade program*-* Download - Beijing RichAuto S&T CO., Ltd
    I flashed my A11 from the image there and then had to figure out how to set the handle to English. Their Facebook page has instructions on how to do this.
  10. #10
    Member Liqiao's Avatar
    Aug 2019
    You can download all document from RichAuto officer website . Download Beijing RichAuto S&T Co. Ltd
    Any problem you can contact me
