RS 232 communication using LABview for modem
Results 1 to 3 of 3
Thread: RS 232 communication using LABview for modem
    Feb 2007
    Malaysia
    Unhappy RS 232 communication using LABview for modem
    hye..i'm a newcomer here and i really need this community help. i'm learning how to communicate with RS 232 modem.how to get the data from RS232 modem...i'm using LAbview basic serial read and write VI. i'm using the AT command but the reponse is the same as the AT command..how to convert the data we get from the modem to the info that we want which is i want the info about the modem..
    Sep 2014
    Default Re: RS 232 communication using LABview for modem
    hi my firend
    if you want use labview for comenionation with another thing you should :
    1- install labview
    2- install real time
    if you want continuance i can help you
    Community Moderator wendtmk's Avatar
    Dec 2005
    I hope he figured it out. His post was from seven years ago.
