Need Help! Bonding Corian to Corian. What to use?
Results 1 to 13 of 13
Thread: Bonding Corian to Corian. What to use?
    Feb 2009
    Default Bonding Corian to Corian. What to use?
    I have some Corian stock in 1/2" sheets. I would like to "lay up" 3 sheets to have 1.5" stock that I can then CNC machine. It seems the "official" bonding material to use for Corian is only available to certified dealers, and a web search seems to indicate that getting a good strong bond is a difficult thing to do.
    Does any one on here have a suggestion based on experience they have had for a good adhesive? It will need to take side load during machining (I may pin the sheets together to take that load). I also would like the adhesive to have nearly the same hardness of the Corian, or be very thin - it should not be obvious that the finished piece is made from multiple pieces. I will be using the machined part as a mold to make castings from, so I don't want the seam of the Corian to telegraph in to the cast part.
    Any specific recommendations for brand and "flavor" of epoxy? Would simple caulk work? Other ideas?
    CAD, CAM, Scanning, Modelling, Machining...
    May 2004
    Straight off the web: How to Glue Corian | eHow.com
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    You can get solid surface adhesives from Glue Warehouse or Integra Adhesives.
    The problem is you need a rather expensive gun to use it.
    You can use any slow setting epoxy. I'd add some filler like West System High Density filler.
    With epoxy, sand it with very coarse sandpaper, and wipe well with denatured alcohol.
    If using solid surface adhesives, you can use finer sandpaper to rough up the surface, but still wipe with the alcohol before gluing.
    UCCNC 2017 Screenset
    Feb 2009
    Well, if you follow that link, you will find it references the Corian adhesive, which as I stated in the original post, is not readily available...
    I take it you don't have personal experience in bonding Corian? That is what I am looking for, and was hoping someone on this board may have relevant knowledge to share.
    Feb 2009
    Thanks, those links got me in to the right chemistry, anyway (neither site has all that much specific data and pricing and online ordering don't seem to be their strengths)! I ordered some Methyl Methacrylate Adhesive from Extreme Adhesives. We'll see how that does!
    May 2004
    Quote Originally Posted by mcphill View Post
    Kept following links and found: Integra Adhesive, Surface Bonder Xi - Adhesive Brands - Adhesives, Applicators & Tips - Tools & Supplies : SurfaceNet, LLC
    Not sure why that was so difficult.
  7. #7
    Jul 2009
    NL
    As far as I know corian is pmma with filler. So the most dangerous (and beautifull) way of bonding pmma may work: chloroform
    Ventilate well...
    Sven http://www.cnczone.com/forums/diy-cnc-router-table-machines/320812-aluminium-1250x1250x250-router.html
  8. #8
    Aug 2006
    I use gap filling super glue all the time on corian. The corian will break before the joint lets go. Gap filling is nice because it generally isn't an instant set so you can position it. Freeman foundry supply has the best prices I've seen.
    Derek
  9. #9
    Feb 2009
    Quote Originally Posted by derek View Post
    Derek
    Are you bonding small parts are large ones? I am wanting to bond 12"x12" sheets together, and as stated, machine down the "block" from there. Will try this next, though, if the adhesive I bought doesn't work. Thanks for the hands-on experiece/feedback.
  10. #10
    Feb 2009
    Acetone makes me lightheaded enough! Don't think I want to test this option...
  11. #11
    Aug 2006
    Yep
    12 x 12 no problem. I use super glue because of the speed and strength.
    A lot of times I'll rough something one layer at a time glueing sections on as needed. this saves a lot of glue and carving time. I then go back and make my finish passes. Also you want an adhesive that dries hard so that it machines cleanly.
    Derek
  12. #12
    Jul 2016
    Default Re: Bonding Corian to Corian. What to use?
    I have had great results using super glue to bond large pieces of Corian together.
  13. #13
    Apr 2014
    I like the Idea Super Glue I made a purpose built fan for gluing with it OOO my eyes and airways.
