hello,
Can someone tell me what does the two digits on the DIAS 3 module means?
i have 18 on the display most of the time and when i try to move the Z axe manually to the cutting height, the head moves in the opposite direction, the display shows 32, and soon reach the upper mechanical limit and stops and 33 is blinking.
The coaxial cable is new. There is no shortcut in the head sensor.
In the machine parameters i have DIAS 3 set properly but when i start a cuting program, i get the message.....Error 60 DIAS IS NOT PROPERLY APPLIED.
The controller is Bosch from 1998. The laser is TC3030 with 2400W.
I also see in the white screen for the manual Z axe the error NC Waiting Telegram Timeout Warning 5347 and NC Waiting BitBus Answer missing Warning 5537.
Any hint will be highly apreciated.
