Ermaksan Fibermak Raptor- Pressure (Bar) for cutting 3mm Alum
Hello, Looking to retrofit our Fibermak Raptor laser with an air line. Currently using Nitrogen BulkPacks and oxygen. Just curious if anyone is familiar with what air pressure we should use. The stock setting on the machine for air with a 3mm alum cut is 10 Bar 145PSI. If you know that this will be enough or too much please let me know. any other cut condition would be appreciated too.
( Power, Height, FeedRate,and Bar) Etc. Someone is coming into the shop to work on our air compressors and we will be speaking to them about the retro fit, so as much information as possible to pass along to them would be greatly appreciated.
We Currently cut aluminum using Nitrogen but the machine recommends using air. as the Nitrogen leaves a little more slag on the bottom of the cut.
