Need Help! laser problem
Results 1 to 1 of 1
Thread: laser problem
    Dec 2016
    Korea, Republic Of
    Default laser problem
    Dear all.
    Most of the work is fine, but when you process the patterned pattern, the part that is pushed in the y-axis occurs
    Also, drawings created with integers are not problematic, and only drawings created with a decimal point cause problems
    ex) 2mm circle pitch 4mm x 4mm 40x40 array (ok)
    1.85mm circle pitch 2.9mm x 2.9mm 40x40 array(fail)
    If you have any problems with me, please reply.
    thanks regard~
laser problem
laser problem
