Bodo Lasercutter power and speed problem
Results 1 to 3 of 3
Thread: Bodo Lasercutter power and speed problem
    *Registered User* utskottet's Avatar
    Nov 2018
    Default Bodo Lasercutter power and speed problem
    I have A BLC BM 120W Laser with a Ruida controller.
    Problem:
    Over 13mm mm/s I get current up to 32 mA on 100% setting
    Under 13mm/s I can only get up to about 18 mA
    Very odd, and of course Bodor support cannot awnser the question.
    I have changed out both laser supply and tube still the same problem.
    Anyone experiancing the same or knows how to fix it ?
    Member CeliaB's Avatar
    Dec 2018
    Default Re: Bodo Lasercutter power and speed problem
    Hello, do you still have the same questions?
    Member germanr's Avatar
    Aug 2018
    Buenos Aires
    I leave this answer as teaching for new users of laser machines.
    Speed has nothing to do with mili Amperes. The amperes have to do with the power of cutting or engraving, which is measured in percentage on the Watts of the tube.
    What I mean is that you can use the same mA at different speeds.
    If I use, for example, a speed of 20 mm / s and a power of 75%, I will have the same amperage as if I use a speed of 5 mm / s and a power of 75%.
    Regards!
    we are:
    BuchiCNC USA
    You can check our CO2 laser cutters here:
    CO2 Laser cutting machines
    If you want a metal laser engraver:
    Laser metal engravers
    Great CNC Router:
    CNC Routers
    Soy tecnico de laser con experiencia.<br />Usuario de maquina de corte laser Buchicnc EVO 14.<br />Usuario de grabadora laser por fibra EVO 5.<br />Usuario de router CNC, con mesa de 3 x 2 mts Auto Tool Changer<br />Diseño mis propios archivos maquinas de corte laser con CorelDraw, LaserCut 5.3, RDWorks V8.<br /><a href="https://buchicnc.com" target="_blank">Estas son mis maquinas de corte láser BuchiCNC</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-14/" target="_blank">EVO 14</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-5/" target="_blank">EVO 5</a><br /><br /><a href="https://buchicnc.com/en/" target="_blank">Laser cutters &amp; CNC Routers BuchiCNC USA</a><br /><a href="https://buchicnc.com/en/product/cnc-router-mr-atc-6-standard-line/" target="_blank">CNC Router ATC</a><br /><a href="https://buchicnc.com/en/product/laser-cutting-machine-evo-14/" target="_blank">EVO 14</a>
