What material are you cutting? MS? SS? what thickness? Your tip may be clogging because your standoff is drifting down to the table. If that is the case, you may have an issue with the lower cone assembly being dirty. CI can help you with cleaning it. I'd guess the tip is hot too (blueish)?
