I have expiriensed the same problem once, the floppy drive was broken. Try whit a new drive.
I can't load programs into the control via floppy. Can anyone help. There are no alarms.
Need urgent help for a Tria 7500 controller. Back-up batteri is gone dead, so the controller lost all data. Need help for the procedure to reinstall data. Got disk whith all data on (original) but need help step for step.
Hey SNS.
I got the procedure for both 503 and 504 whit a Tria 7500 controller.
Just send your mail address and i send it to you.
best Stoned.
Hi Stoned
Thank you.
My email is s.naursgaard@gmail.com
Hope it's works
best SNS
Just send me a valid mail adress, and i post the procedure to you.
Stoned.
Hi Stoned
My email is lllhuy@yahoo.com
lllhuy
Stoned
I would very much appreciate you sending me the proceedures as I to have a dead battery and need to reload.
e-mail CADMAN-LV@hotmail.com
Thank You
CADMAN-LV
Hello every one.... is somebody able to help me?
I have problems with A504K.. when loading the files of the PLC
when this in the installation process
it doesn't finish.... and it puts an error..... "Register not connected Y131"
In other times I had reinstalled those all the parameters
without any problem....
e-mail uvaltierra@oakwest.com
same problem here, I think you have to know how to boot from the floppy disk
does anybody have the instructions on reloading the plc, it just says input/output error
email -admin@highlane.org
Hi Stone,
I have the same problem, can you send me the procedure,
I have a morbidelli Author 504
and my email is
jorgeboga@hotmail.com
THANKS!!
I sure could use this info also. I am also looking for someone familiar with this controller
Thanks Mike
gofastey@aol.com
Hi, can you send me the reloading procedure too if any of you still check these forums.
I have a morbidelli 504
Address is ziptrax@gmail.com
Need Help! Tria 7500 Author 503 morbedelli with automatic tool exchange:Can not find the proper start up discs ours seem to not be working ... contacted scm in the states with no luck tried calling UK with no reply yet. Can anyone help ? Thank you !! iihonest@hotmail.com
Hi all.
Is there anyone who can tell me if you can use G code X Y Z generatet from PC then transfered to the CNC by floppy disk?
example would be nice
I ask because right now we program directly on the CNC point to point and we use autocad to get the point to points and then punch them in manualy and some of the programs are very very long so it would be good to have a program where you can import the autocad drawing and generate the X Y Z and just copy it to a floppy disk and load it as a SUB program.
Any ideas is helpful guys.
Best regards
Flemming
Plz help when i start to reload the plc and put disk in fdd write {errore triaset.sat 1122h generico error} what what do I do cant reload plc email redline5@rambler.ru
Hey redline5.
A generic error on a Tria 7500 can be many things, but the most common is that there is an error an the disk or the disk drive is corrupt.
If i my memory is right, you might have to leave the write protection open on the disk whit the plc files, when you are reloading them.
Unfortuanily i dont work whit a Tria 7500 anymore, so i can`t try i out myself.
Stoned
Dears,
I have problems with Morbideli A510. Try to upgrade PLC bud I guest i have not correct parameters. There is parameter invalid Axis 1,15 and Gendata 1,19?
Any sugestion
Dejan,
I have some parameters for A510 and if you want, i send to you. Mzexster@gmail.com
