Hi KT - By 20 mil do you mean 20mm, 20 millionths of an inch or what? Cam master quote a repeatability of 0.002" or 0.050mm. This sounds Ok to me for this sort of machine. If you are getting a non repeatable part result then its probably a loose set screw on a coupling or motor or ballscrew end so I'd start checking through the mechanics... Peter
