- Bosch CC100 software loading
Need to know how to load the following software into the Bosch CC100 CNC controller:
WAD.CYC
WAD.TXT
WADKIN
We load the parameter file WAD.PAR into the control without any problems using a laptop. After this we reset the control and find that none of the keys will work. If we edit the parameters after installing them we find that they are correct as per the backup.
Thanking you
Gyrodog
cc100
what model of machine is this controller on?
Bosch CC100
Hello jpolin,
Thank you for your reply. We did manage to sort out our problem. The memory had been corrupted and had to be totally re-initialized. The machine has been running ever since without any problems.
Re: Bosch CC100
Hi we have a wadkin ux with 2 head with the 223 reference cycle does not exist error any idea what is the cause of that and the fix ?
Thank you
- You may not post replies
- You may not edit your posts
Forum Rules
