Originally Posted by
FickFab
Little update for anyone that runs across this. We ended up finally speaking with someone local that had some knowledge on this at a small shop we had never heard of, and she recommended we make the switch from 3 flute endmills to a single O flute ZrN coated endmill. So we picked up an Amana 1/4" Single O Flute endmill (pricey) but in doing so we were able to lower our air pressure to 75 PSI so our compressor is no longer running 100% of the time, we are able to turn our mist right down to virtually nothing.. just barely enough to make your finger slightly damp if held in the stream of air. And we are now running as per below.
5052 aluminum sheets with a 1/4" single O flute Amana endmill at 6IPM plunge, 25IPM feed, 18k RPM, 0.065" DOC, and are getting a 0.0045" chip load. The chips are coming off hot, the tool is cold the the touch after 2 hours non stop cutting, we are able to walk away from the machine now and do not have to worry about the endmill plugging up! Now the only concern is breaking the endmill as we have gone through 2 already (1 our fault, maybe both) and they are rather pricey!
On the note of the endmills, if anyone has any experience with Amana endmills. The exact endmill we are using is the Amana 51480-Z, we purchased 3 of these at a cost of $75/each (compared to $17 each before for the 3 flute...). We ended up breaking one of the Amana endmills in a piece of 3/8" aluminum which was just a stupid mistake where we forgot tabs on a piece and it got loose and snapped the endmill when cutting through. But when we swapped the endmill to another brand new one, we went to cut a sheet of 1/8" 5052 aluminum as per the settings above and the second this 100% brand new endmill touched the material on the very first plunge the very tip of the tool broke off and it immediately gummed up and was ruined. We swapped to the last new endmill we had purchased, restarted the program with no changes, and it went on to cut 3 more sheets after that sheet as well without any issues and is still in use today. So 1 out of 3 Amana endmills having what I can only determine as a manufacturing defect seems like really bad odds. We tried to reach out to Amana to gain some insight and they recommended we change our settings to 12k rpm, 30IPM plunge (ramped), 60IPM feed, and .250" DOC. Our machine will not be capable of running these settings as it is a lighter duty machine, and I feel like 30IPM plunge and 60IPM feed at a lower RPM just sounds really fast? The settings as mentioned above that we are running we basically started at 18k rpm as that is what our machine maxes out at, we started at 5IPM plunge and 10IPM feed and used our over ride until the machine started to get a vibration cutting at 30IPM feed, so we found 25IPM was a good feed rate and the chips were coming off at .0045" which is perfect as per the Amana chart, and then just found that 6IPM seemed to be a good plunge rate, not entirely sure on this though. We do a straight plunge to .065" DOC and I am just not familiar with what a good plunge sound should be. Anyways, if anyone has anything they could chime in with on this I would be interested in hearing. This is a learning curve for us and any feedback is appreciated! Thank you
