- SCM tech z30 losing x-axis zero position in-between of cycles
Hi all!
Recently my SCM tech z30 machine has started to give me a huge headache. Namely, time to time, sometimes few times per day, sometimes more rarely, it will lose it's x-axis zero position. When this goes unnoticed, the machine will run into x-min and hit itself against the limit (Happened once, not a good thing). Has anybody encountered a similar problem and can recommend a toubleshooting strategy to get rid of this problme.
In addition, this has happened only with x-axis and only in-between of cycles.
Thanks for any advice!
- You may not post replies
- You may not edit your posts
Forum Rules
