Check your stepper motor could be dragging or missing steps
I have a commercial 2'x4' cnc with rack and pinion drive on X & Y. The machine cuts about 20 mil over size on the far side of the x axis whether its a 3" rectangle or 6" circle. Its close to spot on near x0. The pinion doesn't show wear and is tight against the rack. I've made sure the rack is straight with a straight edge. Checking the x axis resolution shows that it is spot on. Y axis doesn't appear to have this issue. Belt is tight.
I've been cutting mdf for testing this with 1/4" bit, 1/8" DOC, just 50ipm feed at 12k rpm.
What is possibly the issue? Some weird electronics problem?
Try to use a pencil in spindle and have it draw a circle without turning on the motor, just unplug power to VFD. This will let you know if you are getting EMI interference. If the pencil circle are perfect you have a noise issue
Camaster said they would have to send someone out but its a two month wait. Twisted gantry.
WTH causes a twisted gantry?
