Need Help! E.O.C.a code / E.O.C/n Code
Results 1 to 3 of 3
Thread: E.O.C.a code / E.O.C/n Code
    Member melliotardelli's Avatar
    Oct 2021
    Default E.O.C.a code / E.O.C/n Code
    We have a Piranah router 12450 x 1250 which keeps showing up the error codes E.O.C.a and E.O,C,n , the router has run perfect for years, could any one reccomend an electrician to fix the problem, we are in west yorkshire.
    Melvin Feather
    Member mactec54's Avatar
    Jan 2005
    Default Re: E.O.C.a code / E.O.C/n Code
    Quote Originally Posted by melliotardelli View Post
    Very few electricians could solve this problem
    E.O.C. A is over current when ramping up to speed
    E.C.O. n is over current at constant speed
    Your spindle may have damaged that is causing this, check the wiring to the spindle, check the bearings in the spindle do they turn free, have the spindle mega tested at a motor repair shop to test the insulation
    Has it over heated or stalled while cutting, is this air cooled or water cooled
    Mactec54
    Oct 2021
    water cooled
    Melvin Feather
