Newbie Seeking advice: 2x4' router with ATC spindle for $10-15k
Results 1 to 2 of 2
Thread: Seeking advice: 2x4' router with ATC spindle for $10-15k
    Member AdventureTim's Avatar
    Oct 2021
    Question Seeking advice: 2x4' router with ATC spindle for $10-15k
    Hi all,
    I apologise if this topic has been covered numerous times; I searched and scrolled but only found threads that were many years old.
    I'm wanting to buy a CNC router to process hardwood and some light aluminium, with a 2' x 4' working area and an ATC spindle (preferably air-cooled). My budget is ~$15k and it would ideally be turnkey (or close to). I've been looking into the Stepcraft Q.204, but am a little concerned by the round rails on the Y-axis (instead of linear guides) and the lead screw on the Z-axis (instead of a ball screw).
    Other makes that offer products in this segment that I've looked at (Axiom, Shopbot, Camaster). It looks like the Laguna iQ Pro does come with a 2x4' table option that puts it just outside this budget (~$16k). For $15k I should be able to piece together a solution with AvidCNC, but I'd rather get a turnkey solution (and it looks like the Avid uses rack and pinion rather than ball screws for X/Y-axes).
    I'd love any other suggestions to look into and/or experiences with the Stepcraft Q that might allay my fears.
    Thanks in advance!
    EDIT: I should add that I'm planning on working on smaller, detailed parts so repeatability and precision is very important to me.
    Member KT88saturate's Avatar
    Apr 2020
    Default Re: Seeking advice: 2x4' router with ATC spindle for $10-15k
    Quote Originally Posted by AdventureTim View Post
    Hi all,
    Thanks in advance!
    The Laguna is by far the best option. The stepcraft has some bizarre features like a long belt drive system and the bearings you mentioned. Shopbot is good but expensive for the size you're looking for. Camaster is OKAY, but does not have the nice bearing system and screw drive on all axis like the Laguna. ATC isn't even an option, and it's gantry is limited to 9" as an upgrade. Dollar for dollar, Laguna is a better value than all of the other options.
Seeking advice: 2x4' router with ATC spindle for -15k
