- Help Mach3 and exel hd 1224
Hi I have a second hand excel hd 1224 8x4 cnc router,
I have changed the control board for a nmotion mach3 controller.
I have had the machine fully functional but now I have some issues, the x and y axis were not relevant to each other (wouldn't cut a circle) the way I rectified this was to set the steps per to exactly the same as each other (79.5) now this was working great for a while and then I did a reboot and for some reason they became un relative again, I managed to fix it once by changing the y axis steps per and then changing it back and then for some reason after a few projects were run it started playing up again.
I have since change the pc and the usb I was using and still have the same issue
I now also have some other issues, so if I jog the machine manually at full speed it works fine no jittering and very smooth but if I either run a code or tell it to go to zero it stops and starts
Can anybody help please????
I've attached a video of the smooth moving then the return to zero.
Edit the video wont upload
- You may not post replies
- You may not edit your posts
Forum Rules
