Most rotary vane pumps have cast iron housings. If your's stood for any length of time, rust may have developed on the surface the vanes run against. Wouldn't take long for a corroded surface to destroy the graphite vanes. While you've got it apart, you may want to change out the shaft seals as well. They're nowhere near as expensive as the vanes.
