convert shopbot to another software/controller.
Results 1 to 3 of 3
Thread: convert shopbot to another software/controller.
    Jun 2016
    Default convert shopbot to another software/controller.
    Good morning,
    I have an older shopbot PRS with an upgraded controller. I have had intermittent problems with it over the few years I've owned it bot primarily used it with a dragknife to cut vynal. recently it has gone haywire again. A friend suggested that i convert it to mach 3. I need to make this machine reliable and have the full range of abilities with the three axis machine. Any thoughts or recommendations would be greatly appreciated.
    John
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: convert shopbot to another software/controller.
    UCCNC 2017 Screenset
    May 2015
    Without knowing your machine, you might also look at Linuxcnc. It has a broader range of hardware which may let you keep more of your machine intact to keep costs down.
    Rod Webster
    www.vmn.com.au
