Recommend a CNC that will mill 12" thick wood
Results 1 to 8 of 8
Thread: Recommend a CNC that will mill 12" thick wood
    Dingos's Avatar
    Jan 2020
    Default Recommend a CNC that will mill 12" thick wood
    New to the CNC world and am looking for a machine that will be capable of milling a max wood thickness of 12"
    Any recommendations? Budget to USD50k.
    Member handlewanker's Avatar
    Sep 2006
    Default Re: Recommend a CNC that will mill 12" thick wood
    In one hit?????…..that would be some machine.
    Normally a block of wood 12" thick is worked on progressively from the top down, so any CNC router that can handle the length and width (whatever) …...and height...... would do the job.
    The height under the gantry might be the deciding factor.
    Ian.
    Member routalot's Avatar
    Dec 2003
    Before buying a machine get hold of some demo software and learn how to deal with the programming.Two reasons for this recommendation;first it will give you a head start on being productive when a machine arrives and second you need to get familiar with Gcode because you will very likely have to manually edit the programs to avoid a long tool gouging the job on it's way out or back or even refusing to run a sequence that would exceed the working envelope of the machine.It will be less daunting if you are comfortable with the notion of typing a line or two of code.Please also keep in mind that just having a lot of Z axis travel doesn't mean you will be able to cut anything you can fit under the gantry,the geometry of the Z axis backplate and the motor body may prevent getting into some areas.
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi Dingos - I think you need to describe what you want to do. Do you want to cut 12" or carve shapes, proflies? Sculpture etc. The readers need to know this to be able to comment. You say mill so do you mean facing the timber only? Peter
    Dingos's Avatar
    Jan 2020
    Mill a square 12" slab of wood on four sides; reduce part of the profile to half its original z height. Each profile milled independently of the other.
    I have a few leads for some US machines - CAMaster being one that seems to get good reviews.
    Thanks!
    Jun 2007
    canada
    You probably want a tall z 5 axis that can drop down on the sides and mill sideways. Something that can swing a 2" or bigger face mill type cutter on a 6" + extension, or one of the big helical jointer heads.
    That's going to cost a fair bit, even used or from china direct.
    If you are trying to do this on the cheap (as naming camaster suggests) i'm not sure how much luck you will have. Simply having z clearance isn't going to get you there.
  7. #7
    Dec 2013
    What is your work envelope need? Length? Width?
    Jim Dawson
    Sandy, Oregon, USA
  8. #8
    Member machinehop5's Avatar
    Aug 2009
    Something in this size Range?
