- Busellato 4002 not set point
Hi there, I have a Busellato 4002 that don’t setpoint to zero when turn on and a error of Carousel 2 axis not ok shows !!! Of course if there is not setpoint nothings else works, however in order to check the servos I’m able to move manually, in the machine screen, si that means that is operacional. Any idea why is this happening ? Thanks in advance
- You may not post replies
- You may not edit your posts
Forum Rules
