Need Help! problem with axis
Results 1 to 4 of 4
Thread: problem with axis
    *Registered User* jafar45's Avatar
    Nov 2018
    Post problem with axis
    Dear friends i have problem with Weihong NK105
    in 3d machining the Z axis after some steps comes up and some time in the X,Y do shift thank you in advance of your answer
    Member awerby's Avatar
    Apr 2004
    Default Re: problem with axis
    You're losing steps. Try reducing your acceleration value by half and see if things improve.
    Member cncmakers001's Avatar
    Jul 2011
    China
    Quote Originally Posted by jafar45 View Post
    It is better to use AC servo motor and driver, which will be more accurate, the cost are not so big different.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Mar 2017
    China
    Hello, friend,
    Is your machine working with stepper motor? We also met same problem before. Did this happen after the machine working for very long time?
    If so, this is not the problem of the NK105.
    Jinan UnionTech Machinery Co., Ltd.
problem with axis
problem with axis
