Can't Machine a Simple Circle with a Probotix Fireball
Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: Can't Machine a Simple Circle with a Probotix Fireball
    Jan 2014
    Default Can't Machine a Simple Circle with a Probotix Fireball
    For the last two weeks I have been working against degrading operational characteristics of my good old dependable Probotix V90 Fireball. It started with non-circular rings cut out of 1/8" aircraft plywood. It has now gotten so bad that I can't cut concentric circles, let alone hold tolerances to within acceptable levels.
    I'm using Vectric Cut 2D CAM and Planet CNC USB controller. The router is a Ridgid R2401. I checked for backlash, loose rods and guides, and TIR on the router. Everything seems to be fine. I have changed cutting speeds, feed rates, cutters, and even stock hold-down methods.
    I'm using Haas, Hurco, and Bridgeport milling machines at work, so it's not exactly foreign territory. But this problem has me bamboozled.
    Any ideas (besides getting another machine)?
    Dec 2013
    Default Re: Can't Machine a Simple Circle with a Probotix Fireball
    Motor power supply maybe? Is it cutting correctly in one axis and not the other?
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2014
    Jim, it's not really consistent. and ID's and OD's are usually oversized. X or Y axis doesn't seem to matter. I'm not sure how to check the power supply going into the motors. Guess I was looking at a mechanical reason for the problem.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Grab the collet and push and pull on it. If it moves, or feels loose, find out what's loose.
    UCCNC 2017 Screenset
    Dec 2013
    Quote Originally Posted by JPX2000 View Post
    Per your first post, you seemed to have checked the mechanical, so that would lead me to the electrical side. The reason I suggested the motor power supply voltage is that it is common to all axes and your problem seems to be at least on both the X & Y axis.
    That voltage is easy to check. Using a multimeter and with the motors enabled, check the output of the 24VDC power supply, it should be about 24VDC. Also check with the machine running a job. I would expect it to maintain an output of about 24VDC. If it's is sagging to 20VDC or so, then you may have a power supply problem.
    Also take a look at the electrical connections in general in the control box. With the machine disconnected from power, go through and re-tighten each screw terminal, look for corrosion at the terminals and any evidence of heating at the terminals. Also unplug and reconnect each ribbon cable, this ''cleans'' the connections.
    One mechanical thing to check is the couplings between the motors and the lead screws.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2014
    Quote Originally Posted by ger21 View Post
    I already checked that out. I put an indicator on a dowel pin and spun the collet, and got less than 0.0005” TIR.
  7. #7
    Jan 2014
    Quote Originally Posted by Jim Dawson View Post
    Thanks, Jim, I was going to go that direction next. I was also wondering if I was using the wrong post processor, since there are dozens to choose from in the list. Manual programming seems to work a little better but I’m not gonna go there.
  8. #8
    Dec 2013
    Given that the machine has been running well for some time, I would suggest the the post processor you have been using would work fine. The problem seems to have developed recently so think back and see if you can find a point in time that things changed. Because the problem is getting worse over time, that would indicate a mechanical or electrical problem.
    One of the first things that I do when going out to troubleshoot a machine for a customer is to have a chat with the operator to try to understand what happened just before the problem occured.
    Jim Dawson
    Sandy, Oregon, USA
  9. #9
    Jan 2014
    OK, Jim, the only anomaly occurred about 2 months ago when a 1/4" cutter fed right down through 1/2" of plywood into the spoil board. The feed rate was set way too high, causing the spindle holder to flex, resulting in the cutter being pulled down out of the collet about 1/2". I don't think that did any damage, because after checking the program, resetting the feed rate, and cleaning up the boo-boo, the part was cut out nearly as programmed.
    I've no idea how to check for the proper output voltages to the motors. If I don't wire up something myself, I usually don't mess with it. I haven't found a pin-out diagram for this PBX USB board, but I'm still looking. Could I check the voltage outputs without taking off the controller cover? I already did that to make sure that screws were tight on the terminals (they were) and to unplug and replug the headers. That cover is a real PITA to deal with.
    Whatever this is, it's not something obvious. I may have changed some sort of setting in the controller software.
    I do appreciate the time you're taking to help with this. My free time is limited and building season is upon us. If you've any suggestions on measuring the output V that would be great.
  10. #10
    Dec 2013
    There should be a silver box with a several terminals on it, that is the power supply, according to the one pdf I read it should be a 24V supply.
    Should look something like this
    https://ae01.alicdn.com/kf/HTB1KN83L...driver-and.jpg
    Set the multimeter for DC volts and check the voltage across the + and - terminals. Stay away from the L and N terminals, they have line voltage (120VAC?) on them.
    Jim Dawson
    Sandy, Oregon, USA
  11. #11
    Jan 2014
    The rear of my control box is pretty well closed up. There are 4 connectors, one for the X,Y, and Z, plus an A axis for revolving surfaces to be machined, I don't have any exposed terminal screws. the rear of the box looks like the attached photo (not mine, somebody's similar enclosure). There are 5 pins on the connectors, and this is what I'm trying to find. I want to know what each pin powers so that I don't go sticking meter probes onto the wrong ones.
    Can't Machine a Simple Circle with a Probotix Fireball-damage1-jpg
    Opening the enclosure, holding the halves apart, and finding voltage values is not gonna be easy. I'll have to recruit my technophobic spouse to help. Fun.
    One last thought... should I perhaps be thinking about whether the step per unit values are still correct?
  12. #12
    Dec 2013
    Yeah, if your parts are off size but consistent then that would be a symptom of your step unit values being off.
    That box in the pic looks like it had a hard life
    The power supply should be inside of the box. There must be some screws in that box somewhere to take it apart. I just looked at some pictures, it looks like there are screws in the bottom of the box, then the bottom just pulls off. At that point you should be able flip it over and pull the top off and get to everything.
    EDIT: Doing a bit more research, it looks like the power supply might be integrated into the main power board in the box. The other picture I saw with the seperate power supply may have been an upgrade or some kind of mod.
    Jim Dawson
    Sandy, Oregon, USA
  13. #13
    Jun 2010
    Now that IS strange.
    If cuts were undersized then you could be missing pulses, have backlash, or several other things, but OVER-sized?
    Just how much oversized?
    Cheer
    Roger
  14. #14
    Jan 2014
    Quote Originally Posted by RCaffin View Post
    Cheer
    Roger
    Roger, there's no rhyme or reason in the dimensions being out of tolerance. In other words, no pattern. I'll program to cut a circle 1" in diameter. Doesn't matter if I cut full depth (1/8") or just 1/16", the X axis can vary between 0.015" to 0.050" over. Same as with the Y axis. Non concentric, and no matter how many I try, they're never consistent. Beats me. Really was a great little machine for my needs.
  15. #15
    Dec 2013
    Cutting oversize with varying result would indicate that extra pulses are being randomly introduced into the system. This would normally be caused by electrical noise or a bad connection between the computer and the ''box''. It could also be an internal bad connection to the breakout board or to the driver board inside the box. Maybe just a failing board. Or even a problem in the computer.
    Based on this new information I'm going to say that the power supply is probably OK, and that the motors are doing exactly what they're being told to do. Given that the problem seems common to both the X and Y axis, I might start at the computer. If you have another computer available, a good test would be to install it and see if the problem persists.
    Jim Dawson
    Sandy, Oregon, USA
  16. #16
    Jan 2014
    OK, Jim, I wrestled my big PC into the work area and plugged it in. Ran several sample programs. A 1" line cuts at 1", whether X, Y, or diagonally. A 1" circle is 0.020" to 0.050" over on the ID. A 2" ring with a 1" center hole has 0.020" to 0.050" under on the OD, and same over size results as the 1" circle. So, I conclude that the older, more powerful PC doesn't have any effect vs. the newer CNC-dedicated PC.
    These would point directly to a bent cutter or seriously sloppy spindle (router). But that's not the case here. As mentioned before, the TIR on the spindle is less than 0.0005". The clamp holder for the router could be flexing, but that's some wild movement when I cut only 0.0625" at a pass.
    Reckon I'll tear it down when I get time and just try and find... something, anything, I don't know. Thanks for your suggestions.
  17. #17
    Dec 2013
    ''circle is 0.020" to 0.050" over'' That is what is strange, if the steps per unit were off and everything else is OK then the error would be consistent, not vary by 0.030. One thing I didn't ask; is the circle off 0.020 in one axis and 0.050 in the other axis or is it random?
    Will it cut a square that is on size in both axes? How about a square rotated 45° off axis?
    Jim Dawson
    Sandy, Oregon, USA
  18. #18
    Jan 2014
    The offset, or overcut/undercut, is random. It won't cut an on-size square no matter what the orientation. I'm taking a deep look into some of the sub-settings. I still can't find any backlash, but the evidence points to just that very thing.
  19. #19
    Jun 2017
    Have you made any adjustments to backlash correction in the program settings?
    Sent from my LGL84VL using Tapatalk
  20. #20
    Dec 2013
    I'm running out of ideas. There is one other possibility that I can think of that is software related, Constant Velocity (G64) vs. Exact Stop (G61) This can effect some machines. Try using the opposite value.
    Failing any software related issues, I'm going to suggest a control problem, maybe a loose connection, bad solder joint, or just simply a failing board.
    Jim Dawson
    Sandy, Oregon, USA
