- Need Help!- AXYZ Z Series not following G code
I am trying to run a parallel surfacing path on an AXYZ router, and I can't figure out what is wrong with either my code or the machine itself. I'm doing the toolpaths with Fusion360, and the toolpaths look great in the software, as well as when viewed on a separate G code viewer. The pattern I'm trying to machine is similar to a waffle texture, and I'm using a parallel toolpath which should have the Z axis moving up and down while the gantry moves back and forth, yet when I run the code on the AXYZ, the Z plunges to a fixed depth for the first several lines of code. The next issue is that when the Z axis does start varying its height, it doesn't follow the G code and plunges far deeper than the lowest Z point in the code. It's plunging as low as .3 when it shouldn't be going any lower than .6. We've got a tool height sensor, and I've checked several times that everything is functioning correctly, so it's not an issue with tool height. The machine also has some issues with acceleration and deceleration and can't even come close to hitting the programmed feedrate, which isn't all that fast @ 300ipm.
I know this isn't a particularly high end machine, but I'm at a loss of how any professionally built machine couldn't handle a little 3D surfacing, let alone plot a different path than what the G code tells it to do.
Here's a section of G code for anyone who'd like to have a closer look
N10 G90G20
N20(PARALLEL1)
N20 M6T29
N30(LONG HSS BALL END)
N30 S18000M3
N40 G0X5.5003Y21.5505
N50 Z1.35
N60 G0Z0.6864
N70 G1Z0.66F300.
N80 G19G2Y21.5003Z0.61R0.05
N90 Y21.1177Z0.7201R0.6945
N100 G3Y20.8302Z0.6915R0.3205
N110 G2Y20.1162Z0.7213R0.7043
N120 G3Y19.8286Z0.6906R0.325
N130 G2Y19.1162Z0.7213R0.7043
N140 G3Y18.8286Z0.6906R0.325
N150 G2Y18.1162Z0.7213R0.7042
N160 G3Y17.8286Z0.6906R0.3251
N170 G2Y17.1162Z0.7213R0.7042
N180 G3Y16.8286Z0.6906R0.3251
N190 G2Y16.1162Z0.7213R0.7042
N200 G3Y15.8286Z0.6906R0.3251
N210 G2Y15.1162Z0.7213R0.7042
N220 G3Y14.8286Z0.6907R0.325
N230 G2Y14.1162Z0.7213R0.7042
N240 G3Y13.8286Z0.6906R0.3251
N250 G2Y13.1162Z0.7213R0.7042
N260 G3Y12.8286Z0.6907R0.325
N270 G2Y12.1162Z0.7213R0.7042
N280 G3Y11.8286Z0.6906R0.3251
N290 G2Y11.1162Z0.7213R0.7042
N300 G3Y10.8286Z0.6906R0.3251
N310 G2Y10.1162Z0.7213R0.7042
N320 G3Y9.8286Z0.6907R0.325
N330 G2Y9.1162Z0.7213R0.7042
N340 G3Y8.8286Z0.6907R0.325
N350 G2Y8.1162Z0.7213R0.7042
N360 G3Y7.8286Z0.6906R0.3251
N370 G2Y7.1162Z0.7213R0.7042
N380 G3Y6.8286Z0.6906R0.3251
N390 G2Y6.1162Z0.7213R0.7042
N400 G3Y5.8286Z0.6906R0.3251
N410 G2Y5.1162Z0.7213R0.7042
N420 G3Y4.8286Z0.6907R0.325
N430 G2Y4.1162Z0.7213R0.7042
N440 G3Y3.8286Z0.6907R0.325
N450 G2Y3.1162Z0.7213R0.7042
N460 G3Y2.8286Z0.6906R0.3251
N470 G2Y2.1162Z0.7213R0.7042
N480 G3Y1.8286Z0.6906R0.3251
N490 G2Y1.1162Z0.7213R0.7042
N500 G3Y0.8286Z0.6907R0.325
N510 G2Y0.4997Z0.6095R0.6683
N520 G1Y0.4958Z0.61
N530 Y0.4921Z0.611
N540 Y0.4887Z0.6125
N550 G3Y0.4777Z0.6151R0.025
N560 G1Y0.4775
N570 X5.5002Y0.4755
N580 X5.4999Y0.4736
N590 X5.4994Y0.4717Z0.6152
N600 X5.4988Y0.4699
N610 X5.498Y0.4682Z0.6153
N620 X5.497Y0.4665Z0.6154
N630 X5.4958Y0.4649Z0.6155
N640 X5.4945Y0.4635Z0.6156
N650 X5.4931Y0.4622Z0.6158
N660 X5.4915Y0.461Z0.6159
N670 X5.4899Y0.46Z0.6161
N680 X5.4881Y0.4592Z0.6162
N690 X5.4863Y0.4586Z0.6164
N700 X5.4844Y0.4581Z0.6166
N710 X5.4825Y0.4578Z0.6168
N720 X5.4806Y0.4577Z0.617
N730 X5.4787Y0.4578Z0.6171
N740 X5.4768Y0.4581Z0.6173
N750 X5.4749Y0.4586Z0.6175
N760 X5.4731Y0.4592Z0.6177
N770 X5.4713Y0.46Z0.6178
N780 X5.4697Y0.461Z0.618
N790 X5.4681Y0.4622Z0.6181
N800 X5.4667Y0.4635Z0.6183
N810 X5.4654Y0.4649Z0.6184
N820 X5.4642Y0.4665Z0.6185
N830 X5.4632Y0.4682Z0.6186
N840 X5.4624Y0.4699Z0.6187
N850 X5.4618Y0.4717
N860 X5.4613Y0.4736Z0.6188
N870 X5.461Y0.4755
N880 X5.4609Y0.4775
N890 G2Y0.4885Z0.6163R0.025
N900 G3Y0.4995Z0.6137R0.025
N910 Y0.8834Z0.7206R0.72
N920 G2Y1.1781Z0.6865R0.3223
N930 G3Y1.8835Z0.7205R0.7372
N940 G2Y2.1781Z0.6865R0.3213
N950 G3Y2.8835Z0.7205R0.7375
N960 G2Y3.1781Z0.6865R0.3212
N970 G3Y3.8835Z0.7205R0.7375
N980 G2Y4.1781Z0.6865R0.3212
N990 G3Y4.8835Z0.7205R0.7375
N1000 G2Y5.1781Z0.6865R0.3212
N1010 G3Y5.8835Z0.7205R0.7375
N1020 G2Y6.1781Z0.6865R0.3212
N1030 G3Y6.8835Z0.7205R0.7375
N1040 G2Y7.1781Z0.6865R0.3212
N1050 G3Y7.8835Z0.7205R0.7375
N1060 G2Y8.1781Z0.6865R0.3212
N1070 G3Y8.8835Z0.7205R0.7375
N1080 G2Y9.1781Z0.6865R0.3212
N1090 G3Y9.8901Z0.7242R0.739
N1100 G2Y10.1783Z0.6868R0.3317
N1110 G3Y10.8834Z0.7206R0.7346
N1120 G2Y11.1781Z0.6865R0.3221
N1130 G3Y11.8835Z0.7205R0.7373
N1140 G2Y12.1781Z0.6865R0.3213
N1150 G3Y12.8835Z0.7205R0.7375
N1160 G2Y13.1781Z0.6865R0.3212
N1170 G3Y13.8835Z0.7205R0.7375
N1180 G2Y14.1781Z0.6865R0.3212
N1190 G3Y14.8835Z0.7205R0.7376
N1200 G2Y15.1781Z0.6865R0.3212
N1210 G3Y15.8835Z0.7205R0.7375
N1220 G2Y16.1781Z0.6865R0.3212
N1230 G3Y16.8835Z0.7205R0.7375
N1240 G2Y17.1781Z0.6865R0.3212
N1250 G3Y17.8835Z0.7205R0.7376
N1260 G2Y18.1781Z0.6865R0.3212
N1270 G3Y18.8835Z0.7205R0.7376
N1280 G2Y19.1781Z0.6865R0.3212
N1290 G3Y19.8835Z0.7205R0.7376
N1300 G2Y20.1781Z0.6865R0.3212
N1310 G3Y20.8835Z0.7205R0.7376
N1320 G2Y21.1865Z0.6816R0.326
N1330 G3Y21.5005Z0.6129R0.7569
N1340 G1Y21.5043Z0.6135
N1350 Y21.5081Z0.6146
N1360 Y21.5115Z0.6163
N1370 G2Y21.5225Z0.6188R0.025
N1380 G1Y21.5227
N1390 X5.4608Y21.5246
N1400 X5.4605Y21.5265Z0.6189
N1410 X5.4601Y21.5284
N1420 X5.4594Y21.5302Z0.619
N1430 X5.4586Y21.532Z0.6191
N1440 X5.4576Y21.5337Z0.6192
N1450 X5.4564Y21.5352Z0.6193
N1460 X5.4551Y21.5367Z0.6195
N1470 X5.4537Y21.538Z0.6196
N1480 X5.4522Y21.5391Z0.6198
N1490 X5.4505Y21.5401Z0.62
N1500 X5.4488Y21.541Z0.6202
N1510 X5.4469Y21.5416Z0.6204
N1520 X5.4451Y21.5421Z0.6206
N1530 X5.4432Y21.5424Z0.6208
N1540 X5.4412Y21.5425Z0.621
N1550 X5.4393Y21.5424Z0.6213
N1560 X5.4374Y21.5421Z0.6215
N1570 X5.4355Y21.5416Z0.6217
N1580 X5.4337Y21.541Z0.6219
N1590 X5.432Y21.5401Z0.6221
N1600 X5.4303Y21.5391Z0.6223
N1610 X5.4287Y21.538Z0.6224
N1620 X5.4273Y21.5367Z0.6226
N1630 X5.426Y21.5352Z0.6228
N1640 X5.4249Y21.5337Z0.6229
N1650 X5.4239Y21.532Z0.623
N1660 X5.423Y21.5302Z0.6231
N1670 X5.4224Y21.5284Z0.6232
N1680 X5.4219Y21.5265
N1690 X5.4216Y21.5246
N1700 X5.4215Y21.5227Z0.6233
N1710 G3Y21.5117Z0.6207R0.025
N1720 G2Y21.5005Z0.6182R0.025
N1730 Y21.1161Z0.7206R0.7499
N1740 G3Y20.8338Z0.695R0.3238
N1750 G2Y20.116Z0.7209R0.7592
N1760 G3Y19.8338Z0.695R0.3254
N1770 G2Y19.116Z0.7209R0.7587
N1780 G3Y18.8338Z0.695R0.3258
N1790 G2Y18.116Z0.7209R0.7586
N1800 G3Y17.8338Z0.695R0.3259
N1810 G2Y17.116Z0.7209R0.7586
N1820 G3Y16.8338Z0.6951R0.326
N1830 G2Y16.116Z0.7209R0.7585
N1840 G3Y15.8338Z0.6951R0.326
N1850 G2Y15.116Z0.7209R0.7585
N1860 G3Y14.8338Z0.6951R0.3259
N1870 G2Y14.116Z0.7209R0.7586
N1880 G3Y13.8338Z0.6951R0.3259
N1890 G2Y13.116Z0.7209R0.7585
N1900 G3Y12.8338Z0.6951R0.3259
N1910 G2Y12.116Z0.7209R0.7586
N1920 G3Y11.8338Z0.6951R0.3259
N1930 G2Y11.116Z0.7209R0.7586
N1940 G3Y10.8338Z0.6951R0.3259
N1950 G2Y10.116Z0.7209R0.7585
N1960 G3Y9.8338Z0.6951R0.3259
N1970 G2Y9.116Z0.7209R0.7586
N1980 G3Y8.8338Z0.6951R0.3259
N1990 G2Y8.116Z0.7209R0.7585
N2000 G3Y7.8338Z0.6951R0.3259
N2010 G2Y7.116Z0.7209R0.7585
N2020 G3Y6.8338Z0.6951R0.3259
N2030 G2Y6.116Z0.7209R0.7585
N2040 G3Y5.8338Z0.6951R0.3259
N2050 G2Y5.116Z0.7209R0.7585
N2060 G3Y4.8338Z0.6951R0.3259
N2070 G2Y4.116Z0.7209R0.7586
N2080 G3Y3.8338Z0.6951R0.3259
N2090 G2Y3.116Z0.7209R0.7585
N2100 G3Y2.8338Z0.6951R0.3259
N2110 G2Y2.116Z0.7209R0.7585
N2120 G3Y1.8338Z0.6951R0.3259
N2130 G2Y1.116Z0.7209R0.7585
N2140 G3Y0.8338Z0.6951R0.3259
N2150 G2Y0.4995Z0.6179R0.7282
N2160 G1Y0.4957Z0.6183
N2170 Y0.492Z0.6192
N2180 Y0.4884Z0.6207
N2190 G3Y0.4774Z0.6233R0.025
N2200 G1Y0.4773
N2210 Y0.4753
N2220 X5.4212Y0.4734
N2230 X5.4207Y0.4715Z0.6234
N2240 X5.42Y0.4697
N2250 X5.4192Y0.4679Z0.6236
N2260 X5.4182Y0.4663Z0.6237
N2270 X5.4171Y0.4647Z0.6238
N2280 X5.4158Y0.4633Z0.624
N2290 X5.4144Y0.4619Z0.6242
N2300 X5.4128Y0.4608Z0.6244
N2310 X5.4111Y0.4598Z0.6246
N2320 X5.4094Y0.4589Z0.6248
N2330 X5.4076Y0.4583Z0.6251
N2340 X5.4057Y0.4578Z0.6253
N2350 X5.4038Y0.4575Z0.6256
N2360 X5.4019Y0.4574Z0.6258
N2370 X5.3999Y0.4575Z0.6261
N2380 X5.398Y0.4578Z0.6263
N2390 X5.3962Y0.4583Z0.6265
N2400 X5.3943Y0.4589Z0.6268
N2410 X5.3926Y0.4598Z0.627
N2420 X5.3909Y0.4608Z0.6272
N2430 X5.3894Y0.4619Z0.6274
N2440 X5.3879Y0.4633Z0.6276
N2450 X5.3866Y0.4647Z0.6278
N2460 X5.3855Y0.4663Z0.6279
N2470 X5.3845Y0.4679Z0.6281
N2480 X5.3837Y0.4697Z0.6282
N2490 X5.383Y0.4715
N2500 X5.3826Y0.4734Z0.6283
N2510 X5.3823Y0.4753
N2520 X5.3822Y0.4773Z0.6284
N2530 G2Y0.4883Z0.6258R0.025
N2540 G3Y0.4995Z0.6233R0.025
N2550 Y0.8894Z0.7232R0.7932
N2560 G2Y1.181Z0.6874R0.3357
N2570 G3Y1.8896Z0.7229R0.8135
N2580 G2Y2.1809Z0.6873R0.3328
N2590 G3Y2.8896Z0.7228R0.8145
N2600 G2Y3.1809Z0.6873R0.3325
N2610 G3Y3.8896Z0.7228R0.8145
N2620 G2Y4.1809Z0.6873R0.3325
N2630 G3Y4.8896Z0.7228R0.8146
N2640 G2Y5.1809Z0.6873R0.3325
N2650 G3Y5.8896Z0.7228R0.8146
N2660 G2Y6.1809Z0.6873R0.3325
N2670 G3Y6.8896Z0.7228R0.8146
N2680 G2Y7.1809Z0.6873R0.3325
N2690 G3Y7.8896Z0.7228R0.8146
N2700 G2Y8.1809Z0.6873R0.3325
N2710 G3Y8.8896Z0.7228R0.8146
N2720 G2Y9.1809Z0.6873R0.3325
N2730 G3Y9.8896Z0.7228R0.8146
N2740 G2Y10.1809Z0.6873R0.3325
N2750 G3Y10.8896Z0.7228R0.8146
N2760 G2Y11.1809Z0.6873R0.3325
N2770 G3Y11.8896Z0.7228R0.8146
N2780 G2Y12.1809Z0.6873R0.3325
N2790 G3Y12.8896Z0.7228R0.8146
N2800 G2Y13.1809Z0.6873R0.3325
N2810 G3Y13.8896Z0.7228R0.8146
N2820 G2Y14.1809Z0.6873R0.3325
N2830 G3Y14.8896Z0.7228R0.8146
N2840 G2Y15.1809Z0.6873R0.3325
N2850 G3Y15.8896Z0.7228R0.8146
N2860 G2Y16.1809Z0.6873R0.3325
N2870 G3Y16.8896Z0.7228R0.8146
N2880 G2Y17.1809Z0.6873R0.3325
N2890 G3Y17.8896Z0.7228R0.8146
N2900 G2Y18.1809Z0.6873R0.3325
N2910 G3Y18.8896Z0.7228R0.8146
N2920 G2Y19.1809Z0.6873R0.3325
N2930 G3Y19.8896Z0.7228R0.8146
N2940 G2Y20.1809Z0.6873R0.3325
N2950 G3Y20.8964Z0.7265R0.8153
N2960 G2Y21.1726Z0.6924R0.3393
N2970 G3Y21.5005Z0.623R0.79
N2980 G1Y21.5044Z0.6234
N2990 Y21.5082Z0.6243
N3000 Y21.5118Z0.6258
N3010 G2Y21.5228Z0.6284R0.025
N3020 G1X5.3821Y21.5248
N3030 X5.3818Y21.5267
N3040 X5.3813Y21.5286Z0.6285
N3050 X5.3807Y21.5304Z0.6286
N3060 X5.3799Y21.5322Z0.6287
N3070 X5.3789Y21.5339Z0.6288
N3080 X5.3777Y21.5354Z0.629
N3090 X5.3764Y21.5369Z0.6292
N3100 X5.375Y21.5382Z0.6294
N3110 X5.3734Y21.5394Z0.6296
N3120 X5.3718Y21.5404Z0.6299
N3130 X5.37Y21.5412Z0.6301
N3140 X5.3682Y21.5418Z0.6304
N3150 X5.3663Y21.5423Z0.6307
N3160 X5.3644Y21.5426Z0.631
N3170 X5.3625Y21.5427Z0.6313
N3180 X5.3606Y21.5426Z0.6316
N3190 X5.3587Y21.5423Z0.6318
N3200 X5.3568Y21.5418Z0.6321
N3210 X5.355Y21.5412Z0.6324
N3220 X5.3532Y21.5404Z0.6326
N3230 X5.3516Y21.5394Z0.6329
N3240 X5.35Y21.5382Z0.6331
N3250 X5.3486Y21.5369Z0.6333
N3260 X5.3473Y21.5354Z0.6335
N3270 X5.3461Y21.5339Z0.6337
N3280 X5.3451Y21.5322Z0.6338
N3290 X5.3443Y21.5304Z0.634
N3300 X5.3437Y21.5286Z0.6341
N3310 X5.3432Y21.5267
N3320 X5.3429Y21.5248Z0.6342
N3330 X5.3428Y21.5228
N3340 Y21.5227
- You may not post replies
- You may not edit your posts
Forum Rules
