As I'm looking I have thought most about a chinese 6090 type machine.. any alternative thoughts?'
thanks
I have decided to use a CNC router for my composite mold and plug making.. and if possible for my other
endeavors. (very light aluminum machining) and metal casting.
I have some familiarity with autodesk inventor and would probably use their cad ware
At the beginning most of my work would be in foam or wood.
I would like to work up to dimensions of 4 or 5 ft in length perhaps 3 ft in width. that would all be in foam
or wood. If I could get a 4th axis it would be a huge plus.
I realize that there would probably be a lot of finish work after the part is formed but that is not a burden.
My budget would be in the 7000 to $10,000 range.
I was thinking of getting a less expensive machine (a chinese 6040) to learn my way.
Then again it would quickly run out the capacity I need. If I did that I would donate the old machine to
a local community college for their composite program..
I could "assemble" a kit but would rather not design and build my own unit from scratch.
I've read a number of reviews and recommendations on this and other sights. and realize this sort of question has been asked a number of time.
If anyone has used a router for this sort of work any and all suggestions would be welcome.
I am willing to consider any machines manufacture here or abroad.....
I have read a number of times that support is important I appreciate everyone here for their pleasant and tolerant attitude towards us that are new to the endeavor
Joe
thanks
A CNC Router Parts Pro series machine will be the most affordable in the size you need. You can probably get a 4x8 for about $10k.
I wouldn't really bother buying a smaller machine to learn with.
UCCNC 2017 Screenset
I was in a similar situation, and finally decided that if I just bought a cheaper Chinese machine, at least i would have all the moving parts assembled, and I would be able to more quickly get the machine cutting. I would be able to spend my time learning how to make the machine cut what I want, instead of learning how to build the machine.
I found a supplier in Chicago that has Chinese machines in stock. I bought a KL-6090 from Automation Technology and I have been happy with it so far. There was a wiring issue that wasn't hard to figure out, and one issue where the Y axis nut was rubbing on the bottom of the table. My grinder fixed that issue easily enough. I feel that if I had gone with a kit, I might still be building the silly thing instead of actually producing something.
The way I look at it, for the price of the complete Chinese machine, a person can practically strip the electronics and replace with higher quality hardware and still come out money ahead.
