- Need Help!- Holzher 7223 Error #700231 time control gripper close-routing unit
Started machine up after replacing the spindle head and above error will not clear. We cannot reference the Machine. We can manually tool change. We have cleaned the grippers, checked all connections, and checked the tolerance for the grippers (10,5mm +- 0,1mm). We are stuck with no solution. We have been unsuccessful with getting any help from Holzher support. Please Help.
- You may not post replies
- You may not edit your posts
Forum Rules
