I purchased a Gryphon CNC 4' x 8' kit about 9 months ago. I received it about 2 months ago, and finally have it all built, wired, and trying to run parts.
I have Mach3 running to a UC100, to a Leadshine MX4660, all of which was provided as part of the kit.
I added the Huanyang VFD and 2.2kw spindle.
Problem 1: I can't get Mach3 to control the spindle, because the output on the 0-10v is always 8.8v, no matter what settings I try to change in Mach3. I am sure I have something set wrong, but I can't find a solid set of paramters for this machine.
Problem 2: I set the VFD up with the paramters provided by another user here, who seems to be the only person to post a complete set of correct paramters. However, everytime my spindle ramps up, I get a EOCA alarm at around 80hz.
I'd really like to get this machine running, as I have jobs lined up. This is my first built, other than 2 x-carves. I have been running commercial routers for over 10 years, and have 20 years of machining, so I am more of a programmer and operator than a builder.
- Need Help!- MX4660 Speed Control for 2.2 KW huanyang vfd
- Need Help!- MACH 3, Warp9 smooth stepper, Leadshine mx4660 Limit switch home switch woes HELP
- Need Help!- Spindle Relay Control with Mach3 and MX4660
- Need Help!- Leadshine MX4660 Mach 3 Setting
- Mach Control of Huanyang VFD and Spindle through Gecko 540
Looks like i got your settings from another thread. These are what i used.
Ok when you posted in the other thread, it look like you had used those parameters, the list you just posted I don't do it like that anymore as it was to confusing for some people with using one posting to cover all spindles
Make sure these are set, if it still fails you will need to check the Cable from the VFD to Spindle that the connections are correct, next check the spindle plug with a meter
The fault is saying you may have a short in your wiring, but also could be ramp up to speed it is drawing to much current
Pin 1 to Pin 2
Pin2 to Pin 3
Pin 3 to Pin 1
Pin 4 to Ground spindle body
Pd006=15
Pd007=20
Pd008=220
Pd010=10
Pd141=220
Mactec54
Looks like i have a short between pin 1 and 3, but only when the cable is plugged into the spindle. Does that mean a bad spindle?
If the spindle checks out ok, without the cable, then it most likely is how the plug has been connected to the cable, there is not much room in those plugs, and the right wire size must be used this is the correct cable to use for your spindle size
Check the cable by its self, this is where most problems are found
CF6-15-04 you can get this cable from IGUS
Mactec54
This cable CF6-15-04 is there mid-range cable, and will work fine for you, they have more expensive cable per foot, than this that will do the same job as well it's number is
CF35-15-04 TPE
CF31-15-04 PVC
https://www.igus.com/iPro/iPro_01_00....htm?c=US&l=en
file:///D:/Chinese%20Spindles/Chainflex®%20CF35%20motor%20cable%20TPE.pdf
file:///D:/Chinese%20Spindles/Chainflex®%20CF31%20motor%20cable%20PVC.pdf
Mactec54
Hello, I also have a gryphon, and trying to make upgrades to my machine. I will be installing a spindle soon, and would to know how your installation turn out. Currently I'm trying to install a z zero touch plate but cannot get it to work. I've try using pin 13 and 15, following the varies YouTube tutorials and other mx4660 threads on this site, but still no lucky. Does anyone here have any idea on how to install this. I'm using the preload Mach 3 profile "Gryphon V-3 Horizontal". Any help is greatly appreciated.
