Biesse .CIX format - adding parameters for X,Y values etc
Results 1 to 4 of 4
Thread: Biesse .CIX format - adding parameters for X,Y values etc
    Feb 2018
    United Kingdom
    Default Biesse .CIX format - adding parameters for X,Y values etc
    Guys,
    I'm trying to write a sort of parametric .CIX file for a Biesse.
    It seems as though you can have lines like this in the GEO & ROUTG sections:
    PARAM,NAME=XE,VALUE=LPX
    How & where would I set the LPX value?
    Thanks in advance,
    Dave
    Feb 2008
    Afghanistan
    Default Re: Biesse .CIX format - adding parameters for X,Y values etc
    on my older machines- i would just write it into the code
    ie
    n10 lpx=10 lpy=50
    etc
    UCCNC powered uk machine sales
    https://cncrouter.uk/atc-cnc-routers.htm
    Feb 2018
    United Kingdom
    Thank you for this. I'll try it out on the .CIX file.
    Member Bsetek2010's Avatar
    Apr 2019
    LPX, LPY and LPZ are defined in the first section of the CIX file. This is the size of the part.
    Quote Originally Posted by dwhiteley View Post
    Guys,
    Thanks in advance,
    Dave
