Help needed: CNC stormtrooper molds
Results 1 to 4 of 4
Thread: Help needed: CNC stormtrooper molds
    Jan 2018
    Egypt
    Default Help needed: CNC stormtrooper molds
    Hi everyone,
    I'm new to CNC machines, I'm a 3D designer for 3d printing but never stumbled upon designing for CNC machining. I've been involved recently with a project that involves the creation of vacuum forming molds for stormtrooper armour, and I've created 3D models of every mold without any undercuts. My question is, can the model fit a "usual" CNC machine at this scale (largest piece is around 50*36*15cm)?
    And what's a decently sturdy but cheap material to cut it out of? Would casting gypsum blocks work? As it's dirt cheap where I live.
    Thanks in advance!
    Attached Thumbnails Attached Thumbnails Help needed: CNC stormtrooper molds-render-jpg
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Help needed: CNC stormtrooper molds
    At 15cm tall, there's a good chance that you'll have clearance issues with the collet or spindle.
    UCCNC 2017 Screenset
    Jan 2018
    Egypt
    Quote Originally Posted by ger21 View Post
    Thanks for your reply. What would be a safe max height to split the pieces to?
    Mar 2003
    Shelby Township
    Hard to say, but probably in the 5-7cm range. depends on the length of tooling, and how steep the sides of the part are.
